Re: New to me, 63 Mobyelette AV88
Rebel Moby /
Variators original design has 38 x 6,35mm balls on the AV/AU36 and 37 Mobys with notches in the movable cheek shaft so it clicked through "3 speeds". Then they went to 6 x 11,9mm balls, then lost the notches, then just the 3 or 4 ball flavours.
The balls are flyweights that work against the tension of the counter spring on the lower engine mount. More balls will have the variator go from low speed to high speed faster, less balls and the variator will take longer to get to the top 'gear'.
If you are going to castrate your variator you would need to run 2 balls in a 4 ball cage (or a aftermarket 2 ball cage) so you can maintain balance. You would then want to run with a launch lever so you can over ride the flyweights on demand and make it semi automatic.
Alternatively you can just stuff the counter spring to add more tension against the balls.
> John Ebert Wrote:
> I have a question, well 2 really.
> Which is best the 4 ball variator or the 3 ball one? Also while
> researching I read that 1 place recommended that if you are using the 4
> ball one to only use 2 of the balls as that makes the clutch work faster
> or better.
> John in Texas
  New to me, 63 Mobyelette AV88Topic by: John Ebert John Ebert 09/17/19 09:25AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 09/17/19 01:48PM
  Re: New to me, 63 Mobyelette AV88Re: Stephen Keller Stephen Keller 09/17/19 02:07PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 09/17/19 04:52PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 09/17/19 05:39PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 09/18/19 06:42AM
  Re: New to me, 63 Mobyelette AV88Re: Stephen Keller Stephen Keller 09/18/19 02:10PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 09/17/19 05:49PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 09/18/19 06:49AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 09/17/19 05:53PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 09/18/19 06:54AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 09/18/19 06:11PM
  Re: New to me, 63 Mobyelette AV88Re: Kenneth Hill Kenneth Hill 09/19/19 10:26PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 09/20/19 01:34AM
  Re: New to me, 63 Mobyelette AV88Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 10/02/19 09:18AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/02/19 01:11PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/02/19 01:16PM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 10/02/19 01:41PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/05/19 05:58PM
  Re: New to me, 63 Mobyelette AV88Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 10/03/19 01:45AM
  Re: New to me, 63 Mobyelette AV88Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 10/03/19 02:01AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/03/19 04:48PM
  Re: New to me, 63 Mobyelette AV88Re: Aaron Goldman Aaron Goldman 10/20/19 06:57PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/20/19 08:06PM
  Re: New to me, 63 Mobyelette AV88Re: Aaron Goldman Aaron Goldman 10/21/19 06:22AM
  Re: New to me, 63 Mobyelette AV88Re: Brian Terrell Brian Terrell 11/19/19 11:37AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 11/19/19 04:26PM
  Re: New to me, 63 Mobyelette AV88Re: Brian Terrell Brian Terrell 11/19/19 06:10PM
  Re: New to me, 63 Mobyelette AV88Re: Brian Terrell Brian Terrell 11/19/19 11:28PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 11/20/19 05:52AM
  Re: New to me, 63 Mobyelette AV88Re: Rick Bergsma Rick Bergsma 10/02/19 09:16PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/03/19 04:28PM
  Re: New to me, 63 Mobyelette AV88Re: Aaron Blair Aaron Blair 10/03/19 07:25AM
  Re: New to me, 63 Mobyelette AV88Re: Saabsonettguy . Saabsonettguy . 10/04/19 08:02AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/04/19 08:49AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/04/19 09:18AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/04/19 09:29AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/05/19 09:38AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/05/19 10:40AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/06/19 12:05PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/06/19 12:19PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/06/19 12:31PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/08/19 09:04AM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 10/08/19 09:41AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/08/19 10:55AM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 10/08/19 11:14AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/08/19 11:56AM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 10/08/19 01:56PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/08/19 04:45PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/07/19 08:08AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/07/19 11:17AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/07/19 12:15PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/07/19 05:10PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/09/19 09:10AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/15/19 05:46PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/15/19 07:45PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/16/19 05:45AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/16/19 08:54AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/21/19 02:40PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/21/19 07:59PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/22/19 08:12AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/22/19 09:33AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 11/17/19 05:19PM
  Re: New to me, 63 Mobyelette AV88Re: Kenneth Hill Kenneth Hill 12/17/19 08:42AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 12/22/19 04:45PM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 12/22/19 06:05PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 01/06/20 11:04PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 11/02/19 07:13PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 11/04/19 10:32AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 11/16/19 02:21PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 11/16/19 04:04PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 11/16/19 04:51PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 11/16/19 04:58PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 11/17/19 09:56AM
  Re: New to me, 63 Mobyelette AV88Re: pat splat pat splat 01/06/20 11:35PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 01/07/20 08:13AM
  Re: New to me, 63 Mobyelette AV88Re: Kenneth Hill Kenneth Hill 01/07/20 10:42PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 01/08/20 09:44AM
  Re: New to me, 63 Mobyelette AV88Re: Kenneth Hill Kenneth Hill 01/08/20 02:06PM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 01/08/20 03:08PM
  Re: New to me, 63 Mobyelette AV88Re: Kenneth Hill Kenneth Hill 01/08/20 11:20PM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 01/09/20 09:01AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 01/29/20 02:53PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 02/02/20 09:25AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 03/09/20 10:27AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 03/09/20 11:00AM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 03/09/20 11:13AM
  Re: New to me, 63 Mobyelette AV88Re: Kenneth Hill Kenneth Hill 03/10/20 08:38AM
  Re: New to me, 63 Mobyelette AV88Re: Brian Terrell Brian Terrell 03/10/20 09:10AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 03/10/20 09:18AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 03/14/20 10:35AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 03/14/20 11:12AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 03/14/20 11:55AM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 03/14/20 12:08PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 03/14/20 03:37PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 03/14/20 04:19PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 03/15/20 06:14PM
  Re: New to me, 63 Mobyelette AV88Re: Kenneth Hill Kenneth Hill 03/14/20 11:33PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 03/15/20 06:02PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 04/28/20 10:56AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 04/28/20 12:21PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 12/15/20 01:24PM
  Re: New to me, 63 Mobyelette AV88Re: Dirty30 Dillon Dirty30 Dillon 12/15/20 01:34PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 12/15/20 02:21PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 12/16/20 01:45PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 12/18/20 02:29PM
  Re: New to me, 63 Mobyelette AV88Re: Ian T Ian T 04/28/20 03:35PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 04/28/20 04:19PM
