Re: Motomarina Sebring (1987) wheel bearings and more
Daniel '' /
I’m pretty sure I used 6201 bearings in my acorn wheels. You will need a very long center spacer, longer than any of the ones treats has. I cut mine out of steel conduit with a pipe cutter. Also some other spacers to get the wheel in there centered and to space the brake plate out and not drag on the hub.
