Re: Motomarina Sebring (1987) wheel bearings and more
Don Ohio /
> Andrew B Wrote:
> > Don Ohio Wrote:
> > You're welcome!
> Forgot to include the link before. Hope these are the right ones!
> https://www.treatland.tv/sealed-wheel-bearing-MAGIC-for-35mm-ID-12mm-p/sealed-bearing-magic.htm
You gotta measure everything...…...that looks too generic. You can cut your own center spacer, but the O.D. of the bearing must fit perfectly. Get you inside and outside measurements down pat. The spacer must be very strong.
Do some searches on here as this has been discussed many times.
