New here just recently bought a sweet puch maxi
Asking for Thoughts and Prayers y'all
I have a PHBG dellorto and died riding it, sounded like lost of compression or possibly not engaging the clutch so popped it open and have replaced my piston (chunck of the crown missing) new 3 foot clutch (1 of the old 2 foot pad was cracking off) so was thinking this mixture was the cause, now I think it was running fine with those issues and have narrowed it to the carb. I can pour gas into the reedblock and get it to run for a second.
I fully disassembled and cleaned out jet/atomizer 3x, Gas is getting to the bowl but when I twist throttle it doesn't look like gas is spraying. (not sure if that is what I should see on these carbs this is what I am used to seeing on a motorcycle carb) I noted there doesn't look to be an accelerator pump on these carbs so not sure what would cause a lack of gas getting from bowl to the reedblock... or curious if this may be a base setting for these carbs to get it started and tuning? Online research has been no help just tuning while its running which would be great if I could get there...
