left gas running
left my fuel on. flooded the cylinder. exhaust was full of gas. won't start. new plug. regapped timing....
could cylinder be too wet?
Re: left gas running
Pull the plug and let it sit overnight or put it out it the sun for a day.
Bad Cadillac™ /
Change your coil, points, condenser and add premium fuel, it should start then.
> start then.
For a flooded motor ??? What's the logic behind that^ ?
I'd pull the plug and clean it with brake cleaner . Turn the motor over with a drill so there's plenty of revolutions to help evacuate the fuel . Obviously , pull the exhaust and empty .
Put it back together and start with a drill the first time , if needed .(edited)
Bad Cadillac™ /
> > start then.
The logic is, the entire post sounds fake.(edited)
post is not fake.
thanks everybody.
listen, I'll check for spark with my drill.
