> Pops Peds Wrote:
> A good way to cut a clean gasket is place gasket material over the part
> if you have room ..then tap around with a small ball peen hammer..then
> use a pipe ferrel close to the screw or bolt size to cut the hole
> openings..if you cant keep the naterial in place tap and cut a couple of
> holes oposite each other and screw the material to the part to hold it
> in place then tap out your impression ..some times you can cut the
> gasket completly out by tapping it but sometimes use a scissors to
> follow the impression ...some may already know this and some might
> not..it has worked well for me for a lot of years
Old school still rulz. I remember my father showing that way back when everything was black&white and all sound was in mono.
