Re: Tomos a35 home made base gasket problem. Need help plz?
Saabsonettguy . /
Get a sheet of felpro paper to cut your own gaskets out of, any auto parts store should have it. I like the dark gray rubber/fiber type. The factory a35 base gasket is quite thin, and the transfer ports aren't fully open at BDC from the factory. There may be some improvement to be make by raising the cylinder slightly, however this also lowers the piston at TDC so you're reducing the compression at the same time.
  Tomos a35 home made base gasket problem. Need help plz?Topic by: mark alan mark alan 09/15/19 08:44PM
  Re: Tomos a35 home made base gasket problem. Need help plz?Re: Daniel '' Daniel '' 09/15/19 09:45PM
  Re: Tomos a35 home made base gasket problem. Need help plz?Re: mark alan mark alan 09/15/19 09:57PM
  Re: Tomos a35 home made base gasket problem. Need help plz?Re: P D P D 09/16/19 08:47AM
  Re: Tomos a35 home made base gasket problem. Need help plz?Re: ♣Slew Foot♣ ♣Slew Foot♣ 09/16/19 09:09AM
  Re: Tomos a35 home made base gasket problem. Need help plz?Re: mark alan mark alan 09/16/19 09:28AM
  Re: Tomos a35 home made base gasket problem. Need help plz?Re: ♣Slew Foot♣ ♣Slew Foot♣ 09/18/19 02:09AM
  Re: Tomos a35 home made base gasket problem. Need help plz?Re: Den 23 Den 23 10/09/21 06:30PM
  Re: Tomos a35 home made base gasket problem. Need help plz?Re: Saabsonettguy . Saabsonettguy . 10/10/21 08:25AM
  Re: Tomos a35 home made base gasket problem. Need help plz?Re: mark alan mark alan 09/16/19 09:50AM
  Re: Tomos a35 home made base gasket problem. Need help plz?Re: Jeff Parr Jeff Parr 09/18/19 09:35AM
  Re: Tomos a35 home made base gasket problem. Need help plz?Re: John Painter John Painter 10/09/21 04:24PM
  Re: Tomos a35 home made base gasket problem. Need help plz?Re: Saabsonettguy . Saabsonettguy . 09/18/19 01:18PM
  Re: Tomos a35 home made base gasket problem. Need help plz?Re: mark alan mark alan 09/18/19 03:43PM
  Re: Tomos a35 home made base gasket problem. Need help plz?Re: P D P D 09/18/19 06:29PM
  Re: Tomos a35 home made base gasket problem. Need help plz?Re: Pops Peds Pops Peds 09/19/19 10:38AM
  Re: Tomos a35 home made base gasket problem. Need help plz?Re: Jeff Parr Jeff Parr 09/19/19 01:09PM
  Re: Tomos a35 home made base gasket problem. Need help plz?Re: Pops Peds Pops Peds 09/19/19 03:10PM
  Re: Tomos a35 home made base gasket problem. Need help plz?Re: mark alan mark alan 09/19/19 01:35PM
  Re: Tomos a35 home made base gasket problem. Need help plz?Re: Jesse Nordlander Jesse Nordlander 10/10/21 10:13AM
