Garelli clutch
Hi everyone, is there a thread detailing how to inspect/ check the clutch rubbers?
Cannot figure how to do it?
1974 Bimatic.
Re: Garelli clutch
Jamie Bennett /
It looks like this.
Re: Garelli clutch
What's it doing why you want to inspect them?
Re: Garelli clutch
Jamie Bennett /
Poor idle, once it's warmed up a bit there is a vast improvement.
Re: Garelli clutch
If it was the clutch it would be the other way around. What carb and air filter you running?
Re: Garelli clutch
Jamie Bennett /
It's all standard as far as I know, just overhauled carb awaiting exhaust gasket to try again, is it a big job to inspect the rubbers?
Re: Garelli clutch
> filter you running?
this^^, id say clean the carb again and run a inline fuel filter if u dont have one. there might be an air leak somewhere or head bolts loose, or points dirty. or plug fouled, id say clean out the oil n rubber bits on the tranny side, its a bit tricky to reinstall the star plate if u dont have rubber new nipples, pictured above is pop rivets. also a bummer if u mess up the cover gasket while taking it off.
Re: Garelli clutch
Jamie Bennett /
Thank you, will get the filter sorted, it's a non standard tank, the old ones beyond repair.
