Re: Blew out the lights!!!
Probably Fred /
Depending on year but if stock 1980 6 wire Stator it self excites and self regulates itself as long as you use the correct wattage bulbs,
if you do not use the correct wattage bulbs yeah you can start blowing something, (21w head light, .5w speedo, 10w brake light and 5w tail light,)
If someone modified it hardwired it or anything else like putting all the lights on one coil yeah you could blow some stuff, you should have a 21 W coil, a 10 W coil, a 5 W coil, and a ignition coil,
The air gap has to be in specs too,
I run several 55 mph kitted bikes and occasionally one of my bikes tail light burns out, but that only happened like twice in 10 years and I found a 7w bulb that didn’t blow or make any of the other bulbs blow,
I had a problem with the headlight blowing out on a magnum do to tip of the bulb solder melting but cleaning the contact and putting another blob of solder on the bulb and it worked fine
