Re: High Transmission(?) Resistance (Honda NC50)
live ɘvil /
> Zennon Krebsbach Wrote:
> Now that I got my bike running good, I’m squeezing all performance I
> can out of stock. One thing I noticed is how stiff the rear wheel seems
> to spin. It’s hard to illustrate, but I can spin it with one finger,
> (with about half finger strength).
> 1. How stiff should I expect the rear wheel to spin (while disengaged
> from engine)?
> 2. Any common remedies? (Besides hitting the spline bearing with WD)
The spline is for attaching the wheel. No lube on splines will help. Did you replace the seal and bearing on the spline shaft? Keep in mind you are spinning all sorts of gears, sprockets and chains inside the transmission without ever engaging the motor. (edited)
