Re: Tomos cdi no spark condition.
♣Slew Foot♣ /
Before you do all that bypass your kill switch rerun the signal wire right into the box make sure the ground goes right to the engine from the box if it's a four wire and has the external trigger make sure all lines to the trigger are good make sure the trigger is secure and in the right place if it only has two that means it has a hall effect sensor built in or it's an earlier Point / CDI
