Tomos sprint usually runs well low heat. But today engine ran hot and pipe as well.
Might be running lean. Check the basics, fuel filter, main jet and float level. How hot, and a35 or a55? Are you still running the oil pump?
Delete that repeat post b4 you get swarmed on foo. I almost responded to both of em. Gets confusing.hella baked 2, just ripped my gila a55 swapped cr500 70mph down the jersey turnpike w a thic grl on the back at 12oclock and she would have fallen off except for the sharp ass full set i just put on her. its been one of those days bro.
Fuel line is clear. Jets clean a35 #58 jet. Stock with biturbo and air box with few holes drilled out... So?
I premix 32:1 and float level fine.
Been getting a ton of carbon buildup on top of the piston also.
Im new. And i tried i don't know how to delete it.
yeah mixing at 30 2 1 ratio will do that it's recommended you use 50 to 1 or 2.5 oz to a gallon
Ok ill cut back on it. Run 50:1
