Re: 77 Vespa Bravo Hard to Start wont stay running.
Kenny Shinneman /
I did try removing the air filter completely and had the same result. What more does the choke do other than blocking the opening then allow full flow when off? I have tried with choke on, its starts, will idle short time die. When I try to restart with choke off it will start then die. After this most of the time then I have to pedal fast with throttle wide open to get it to run will run short time then die. With fuel coming out the exhaust. I purchased this from original owner 84 year old lady that stopped riding it years ago and has set. I't doesn't look like the main jet has been drilled but I may purchase several different sizes to play with.
Thanks for the help.
  77 Vespa Bravo Hard to Start wont stay running.Topic by: Kenny Shinneman Kenny Shinneman 09/10/19 09:06PM
  Re: 77 Vespa Bravo Hard to Start wont stay running.Re: P D P D 09/11/19 08:10AM
  Re: 77 Vespa Bravo Hard to Start wont stay running.Re: Kenny Shinneman Kenny Shinneman 09/11/19 10:33AM
  Re: 77 Vespa Bravo Hard to Start wont stay running.Re: Bad Cadillac™ Bad Cadillac™ 09/11/19 10:22AM
  Re: 77 Vespa Bravo Hard to Start wont stay running.Re: Kenny Shinneman Kenny Shinneman 09/11/19 10:38AM
  Re: 77 Vespa Bravo Hard to Start wont stay running.Re: alex . alex . 09/11/19 03:47PM
  Re: 77 Vespa Bravo Hard to Start wont stay running.Re: Kenny Shinneman Kenny Shinneman 09/11/19 04:20PM
  Re: 77 Vespa Bravo Hard to Start wont stay running.Re: Bad Cadillac™ Bad Cadillac™ 09/11/19 04:45PM
  Re: 77 Vespa Bravo Hard to Start wont stay running.Re: Bad Cadillac™ Bad Cadillac™ 09/11/19 05:45PM
  Re: 77 Vespa Bravo Hard to Start wont stay running.Re: pat splat pat splat 09/12/19 06:47AM
  Re: 77 Vespa Bravo Hard to Start wont stay running.Re: Ike Pipe Ike Pipe 09/17/19 11:58PM
  Re: 77 Vespa Bravo Hard to Start wont stay running.Re: Kenny Shinneman Kenny Shinneman 09/27/19 08:26AM
  Re: 77 Vespa Bravo Hard to Start wont stay running.Re: Ike Pipe Ike Pipe 09/28/19 12:14AM
  Re: 77 Vespa Bravo Hard to Start wont stay running.Re: pat splat pat splat 09/28/19 09:17AM
  Re: 77 Vespa Bravo Hard to Start wont stay running.Re: Richard Eberline Richard Eberline 09/28/19 10:38AM
