Re: Help with Sachs 505 clutch / starter cable
Double Trouble Dan /
Buy or find a stock airbox .
https://www.treatland.tv/complete-stock-SACHS-square-airbox-p/complete-stock-sachs-airbox.htm
Then clean the jet, scrape the float bowl clean , and re-set the float height even though the manual says that it is not adjustable . Flip the carb over and make sure it is level with the body.
If it is , leave it alone.
That will solve the stalling .
The carb is getting too lean and running low on fuel because the lack of restriction is allowing too much air.
There are other pretty easy ways to fix this , like upsizing the jet , or playing with not stock air filters and restricting them partially , but unless you have some experience doing this, its easier to go with a stock setup.
  Help with Sachs 505 clutch / starter cableTopic by: Ryan Brad Ryan Brad 09/10/19 06:28PM
  Re: Help with Sachs 505 clutch / starter cableRe: ♣Slew Foot♣ ♣Slew Foot♣ 09/10/19 08:36PM
  Re: Help with Sachs 505 clutch / starter cableRe: Nick MBC Nick MBC 09/10/19 08:40PM
  Re: Help with Sachs 505 clutch / starter cableRe: ♣Slew Foot♣ ♣Slew Foot♣ 09/12/19 09:21AM
  Re: Help with Sachs 505 clutch / starter cableRe: Born to be WillD Born to be WillD 09/19/19 09:05PM
  Re: Help with Sachs 505 clutch / starter cableRe: Nick MBC Nick MBC 09/19/19 09:07PM
  Re: Help with Sachs 505 clutch / starter cableRe: P D P D 09/19/19 09:19PM
  Re: Help with Sachs 505 clutch / starter cableRe: Ryan Brad Ryan Brad 09/20/19 12:26PM
  Re: Help with Sachs 505 clutch / starter cableRe: Born to be WillD Born to be WillD 09/23/19 03:08PM
  Re: Help with Sachs 505 clutch / starter cableRe: Born to be WillD Born to be WillD 09/12/19 09:04AM
  Re: Help with Sachs 505 clutch / starter cableRe: Nick MBC Nick MBC 09/12/19 10:24AM
  Re: Help with Sachs 505 clutch / starter cableRe: Ryan Brad Ryan Brad 09/12/19 05:12PM
  Re: Help with Sachs 505 clutch / starter cableRe: Ryan Brad Ryan Brad 09/19/19 04:31PM
  Re: Help with Sachs 505 clutch / starter cableRe: Double Trouble Dan Double Trouble Dan 11/17/19 03:27PM
  Re: Help with Sachs 505 clutch / starter cableRe: Daniel '' Daniel '' 09/20/19 02:13PM
  Re: Help with Sachs 505 clutch / starter cableRe: Nick MBC Nick MBC 09/19/19 04:46PM
  Re: Help with Sachs 505 clutch / starter cableRe: Austin M Austin M 11/17/19 02:58PM
  Re: Help with Sachs 505 clutch / starter cableRe: Born to be WillD Born to be WillD 11/17/19 03:49PM
  Re: Help with Sachs 505 clutch / starter cableRe: Double Trouble Dan Double Trouble Dan 11/17/19 05:07PM
  Re: Help with Sachs 505 clutch / starter cableRe: Born to be WillD Born to be WillD 11/19/19 10:57AM
