Re: Help with Sachs 505 clutch / starter cable
Ryan Brad /
I did take apart and reassemble the clutch. Do I need to lube each plate/pad up before reassembly? I didn't have a piston stop to tighten the clutch nut very much, so I think that may be an issue as well. I will check to make sure the cable is not stuck in the clutch bell, but I don't think that it is. I'll also check the flywheel asap and let you guys know more.
  Help with Sachs 505 clutch / starter cableTopic by: Ryan Brad Ryan Brad 09/10/19 06:28PM
  Re: Help with Sachs 505 clutch / starter cableRe: ♣Slew Foot♣ ♣Slew Foot♣ 09/10/19 08:36PM
  Re: Help with Sachs 505 clutch / starter cableRe: Nick MBC Nick MBC 09/10/19 08:40PM
  Re: Help with Sachs 505 clutch / starter cableRe: ♣Slew Foot♣ ♣Slew Foot♣ 09/12/19 09:21AM
  Re: Help with Sachs 505 clutch / starter cableRe: Born to be WillD Born to be WillD 09/19/19 09:05PM
  Re: Help with Sachs 505 clutch / starter cableRe: Nick MBC Nick MBC 09/19/19 09:07PM
  Re: Help with Sachs 505 clutch / starter cableRe: P D P D 09/19/19 09:19PM
  Re: Help with Sachs 505 clutch / starter cableRe: Ryan Brad Ryan Brad 09/20/19 12:26PM
  Re: Help with Sachs 505 clutch / starter cableRe: Born to be WillD Born to be WillD 09/23/19 03:08PM
  Re: Help with Sachs 505 clutch / starter cableRe: Born to be WillD Born to be WillD 09/12/19 09:04AM
  Re: Help with Sachs 505 clutch / starter cableRe: Nick MBC Nick MBC 09/12/19 10:24AM
  Re: Help with Sachs 505 clutch / starter cableRe: Ryan Brad Ryan Brad 09/12/19 05:12PM
  Re: Help with Sachs 505 clutch / starter cableRe: Ryan Brad Ryan Brad 09/19/19 04:31PM
  Re: Help with Sachs 505 clutch / starter cableRe: Double Trouble Dan Double Trouble Dan 11/17/19 03:27PM
  Re: Help with Sachs 505 clutch / starter cableRe: Daniel '' Daniel '' 09/20/19 02:13PM
  Re: Help with Sachs 505 clutch / starter cableRe: Nick MBC Nick MBC 09/19/19 04:46PM
  Re: Help with Sachs 505 clutch / starter cableRe: Austin M Austin M 11/17/19 02:58PM
  Re: Help with Sachs 505 clutch / starter cableRe: Born to be WillD Born to be WillD 11/17/19 03:49PM
  Re: Help with Sachs 505 clutch / starter cableRe: Double Trouble Dan Double Trouble Dan 11/17/19 05:07PM
  Re: Help with Sachs 505 clutch / starter cableRe: Born to be WillD Born to be WillD 11/19/19 10:57AM
