Help with Sachs 505 clutch / starter cable
Ryan Brad /
Hello, I bought an Eagle III with a Sachs 505 on it, and was running at the time that I picked it up. A day or so later, the starter cable broke from the lever, and was frayed so I had to replace the cable.
Once I got into the case I dissassembled and reassembled the clutch per this video just to get an idea of what i'll be working with on this ped.
I've ordered a starter cable from treat, but in the meantime installed a bike brake cable in it's place (well documented on MA). The cable seems to be installed okay and is engaging the clutch arm against the bell when pulled. When I try to start the bike however, it doesn't turn over at all and the chain / pedals locks up.
Any advice on what I should look at next? I think i need to use a piston stop in order to get the nut on the clutch assembly a little tighter, and need to adjust the clearance between the starter arm nut and the bell a hair, I don't think the nut fully releases off the bell when the cable is disengaged, but that shouldn't cause the chain to lock up right?
This is my first time working on a moped so any advice would be much appreciated. It's also been sitting for a little bit maybe 3 weeks or so, so not sure if I need to do anything with the carb etc, but my gut says there's something not right with the clutch. Please help!
I did fill it with type F trans fluid. Do I need to make sure to lube up each piece on the clutch with trans fluid? Upon reassembly?
  Help with Sachs 505 clutch / starter cableTopic by: Ryan Brad Ryan Brad 09/10/19 06:28PM
  Re: Help with Sachs 505 clutch / starter cableRe: ♣Slew Foot♣ ♣Slew Foot♣ 09/10/19 08:36PM
  Re: Help with Sachs 505 clutch / starter cableRe: Nick MBC Nick MBC 09/10/19 08:40PM
  Re: Help with Sachs 505 clutch / starter cableRe: ♣Slew Foot♣ ♣Slew Foot♣ 09/12/19 09:21AM
  Re: Help with Sachs 505 clutch / starter cableRe: Born to be WillD Born to be WillD 09/19/19 09:05PM
  Re: Help with Sachs 505 clutch / starter cableRe: Nick MBC Nick MBC 09/19/19 09:07PM
  Re: Help with Sachs 505 clutch / starter cableRe: P D P D 09/19/19 09:19PM
  Re: Help with Sachs 505 clutch / starter cableRe: Ryan Brad Ryan Brad 09/20/19 12:26PM
  Re: Help with Sachs 505 clutch / starter cableRe: Born to be WillD Born to be WillD 09/23/19 03:08PM
  Re: Help with Sachs 505 clutch / starter cableRe: Born to be WillD Born to be WillD 09/12/19 09:04AM
  Re: Help with Sachs 505 clutch / starter cableRe: Nick MBC Nick MBC 09/12/19 10:24AM
  Re: Help with Sachs 505 clutch / starter cableRe: Ryan Brad Ryan Brad 09/12/19 05:12PM
  Re: Help with Sachs 505 clutch / starter cableRe: Ryan Brad Ryan Brad 09/19/19 04:31PM
  Re: Help with Sachs 505 clutch / starter cableRe: Double Trouble Dan Double Trouble Dan 11/17/19 03:27PM
  Re: Help with Sachs 505 clutch / starter cableRe: Daniel '' Daniel '' 09/20/19 02:13PM
  Re: Help with Sachs 505 clutch / starter cableRe: Nick MBC Nick MBC 09/19/19 04:46PM
  Re: Help with Sachs 505 clutch / starter cableRe: Austin M Austin M 11/17/19 02:58PM
  Re: Help with Sachs 505 clutch / starter cableRe: Born to be WillD Born to be WillD 11/17/19 03:49PM
  Re: Help with Sachs 505 clutch / starter cableRe: Double Trouble Dan Double Trouble Dan 11/17/19 05:07PM
  Re: Help with Sachs 505 clutch / starter cableRe: Born to be WillD Born to be WillD 11/19/19 10:57AM
