Speedo case for smaller VDO? Can anyone "print" something for me?
I just got a set of the 3D Printed Switch bases from treats. No more busted switch mounts and they seem to work great.
Is there anyone out there that could make, print, a stock looking Speedo case for the smaller VDO 45mph speedometers that are out there. I got one of ebay and was disappointed it's too small for the stock case.
Re: Speedo case for smaller VDO? Can anyone "print" something for me?
♣Slew Foot♣ /
Slapping old-school cev bucket with a batavus speedo they're small you might be able to fit right in and it has a fancy switch blocks and switches and a high beam indicator and a weird thing that looks like a key but it's actually for a dummy plug to start
it has the rocker switches and lights horn externally originally a battery set up for a VA you could probably find one cheap...
Probably Fred /
Make it out of 1/4 plywood and paint it black
♣Slew Foot♣ /
If it's a do-it-yourself project you could take temperature gauge from a gas grill and just gut it and put the speedo in there
I'd like it to fit in the stock PUCH speedo housing if possible. I may try to find some PVC pipe I can fit around it to bring it up to the same diameter and just paint that black. If I get a 3D printer, I can make my own stock looking housing. Now I have a temp guage and a tachometer to deal with too.
♣Slew Foot♣ /
What sort of bucket does it have I mean the cev fits on almost every moped
