Jawa 210 wiring question
Eric Butterfield /
Ok, I got this thing running by doing the Puch 15mm intake and SHA carb upgrade. Still need some help dialing in the carb as I need to raise the idle and fix a minor bog. I’ll talk about that later.
Right now I’m trying to figure out the wiring. Can someone look at this pic and tell me if I’m missing something? On the wiring schematic, it shows an extra green wire that I don’t seem to have. I can’t really tell if it’s missing or if it wasn’t ever there. What would the symptoms be without that wire?
I figured out the horn, but still don’t have brake lights. The bulb appears to be good. Headlight and tail light are both working.
Re: Jawa 210 wiring question
Yes you are missing the green jumper wire that goes between the bottom two coils
Eric Butterfield /
so, what would the symptoms be with missing this jumper? Just curious...
Richard Eberline /
You asked if you were missing something? then you asked another question, without any thanks. Have a nice day.
Eric Butterfield /
Not exactly accurate, Richard. I re-asked the second part of my original question. But at the end of the day, your right. Gratitude was deserved and I failed to deliver it.... my bad.
Rebel, thank you for taking time to help me with this bike. If anyone has an answer to the second part of my question, I'd be grateful for any input. Relatively new to this hobby, so just trying to head off any issues this might cause.
You will have diminished wattage available for your accessories
Eric Butterfield /
ok, that's what i was thinking, but wiring isn't my strong suit. I appreciate your help. I'll solder on a new jumper wire this weekend.
Thanks again!
