Tomos cog removal
I got an a35. Had a first gear clutch shoe crack and fragment and it chipped a tooth on the second gear cog that's on the main shaft. I removed the nut and washer. I thought from the diagram that the nut was holding the gears to the shaft and it would slide off but I'm wrong. I got a clutch puller on it but it still won't budge. Help a dumbass out
Re: Tomos cog removal
Pickle fork
Try a balljoint press install remover tool or bring it to a shop have it pressed off new one put on. I used the balljoint tool for that purpose also works on the clutch bell when removing or pressing the one way bearing. Like a mini press.
♣Slew Foot♣ /
Check your metric extensions for your sockets I bet you one slips right through and hangs out on the other side and you get the right thing on there you give it one good whack with a brass hammer and it pops a ball joint Fork Works in that kind of situation to
I haven't removed the gears from the case, I got the 3 claw clutch puller on it. I think it should do the same thing as the pickle fork. Once I figure out how to get the cog to slide off the shaft, the rest shouldn't be an issue
WHOA WHOA WHOA.....thhose gears just pull right out by hand! What are you doing?
wiggle it out n work on a bench
I'm trying to pull the second gear off the shaft. I don't think putting it on my bench is going to make a big difference. All the diagrams I've looked at show the small cog coming off this way. I'm gonna wiggle wiggle wiggle now
A very persistent wiggle was all I needed. Thanks y'allz
