Re: 1982 honda express Nc50 2 speed idle issue
Sean Daugherty /
Okay so probably an air leak or clogged carb. This week I will spray around with brake cleaner and see if there are any leaks. If not then I will pull the carb off and clean it out thoroughly.
I should probably run an inline filter as well.
I have the oil injector still hooked up so even if I'm lean on fuel will there still be oil mixing into the cylinder?
  1982 honda express Nc50 2 speed idle issueTopic by: Sean Daugherty Sean Daugherty 09/07/19 05:51PM
  Re: 1982 honda express Nc50 2 speed idle issueRe: P D P D 09/07/19 07:20PM
  Re: 1982 honda express Nc50 2 speed idle issueRe: live ɘvil live ɘvil 09/08/19 10:21AM
  Re: 1982 honda express Nc50 2 speed idle issueRe: Sean Daugherty Sean Daugherty 09/08/19 01:45PM
  Re: 1982 honda express Nc50 2 speed idle issueRe: live ɘvil live ɘvil 09/08/19 06:18PM
  Re: 1982 honda express Nc50 2 speed idle issueRe: Sean Daugherty Sean Daugherty 09/08/19 07:41PM
  Re: 1982 honda express Nc50 2 speed idle issueRe: P D P D 09/08/19 08:21PM
  Re: 1982 honda express Nc50 2 speed idle issueRe: Sean Daugherty Sean Daugherty 09/08/19 10:20PM
  Re: 1982 honda express Nc50 2 speed idle issueRe: live ɘvil live ɘvil 09/08/19 10:45PM
  Re: 1982 honda express Nc50 2 speed idle issueRe: Sean Daugherty Sean Daugherty 09/09/19 09:47AM
  Re: 1982 honda express Nc50 2 speed idle issueRe: live ɘvil live ɘvil 09/09/19 07:25PM
  Re: 1982 honda express Nc50 2 speed idle issueRe: Sean Daugherty Sean Daugherty 09/09/19 08:42PM
  Re: 1982 honda express Nc50 2 speed idle issueRe: P D P D 09/09/19 08:49PM
  Re: 1982 honda express Nc50 2 speed idle issueRe: Sean Daugherty Sean Daugherty 09/09/19 08:54PM
  Re: 1982 honda express Nc50 2 speed idle issueRe: Sean Daugherty Sean Daugherty 09/09/19 06:28PM
  Re: 1982 honda express Nc50 2 speed idle issueRe: Jack Rutherford Jack Rutherford 09/09/19 09:03PM
  Re: 1982 honda express Nc50 2 speed idle issueRe: Sean Daugherty Sean Daugherty 09/10/19 09:37AM
  Re: 1982 honda express Nc50 2 speed idle issueRe: P D P D 09/10/19 09:43AM
  Re: 1982 honda express Nc50 2 speed idle issueRe: Sean Daugherty Sean Daugherty 09/10/19 10:13AM
