Re: Why These Vespa Bravo Forks So Soft?
Matthew Coles /
I read through Joe's thread, and based on that, modified my super-soft Bravo front shocks by adding external springs as shown in the other images in the thread. I ordered two sets of springs from Century Springs since I couldn't find anything that seemed like it'd fit locally. One set I ordered was a bit too stiff, but the other seems just about perfect. It's part 3394, with the following specs:
Material Spring Steel - SPR
Wire Dia (in) 0.135
O. D. (in) 1.390
I. D. (in) 1.120
Free Length (in) 5.50
Total Coils 17.00
Rate (lb/in) 16.00
Ends Closed - C
Suggested Max Load (lb) 49.000
Suggested Max Deflection (in) 3.100
Solid Length (in) 2.43
Standard Finish Zinc - Z
These are $10 each, and seem to preserve the "Bravo bounce" without feeling like using the front brakes is going to throw you forward off the bike. I'm a little concerned that the fender will rub against it ever so slightly, but since mine is a bit of a beater, it's not that big a deal for me personally.
Hopefully that's useful to anyone else out there looking to improve their own Bravo shocks.
