Re: Garelli brakes wearing out quickly
P D /
> live ɘvil Wrote:
> The Garelli (others too) brake backing plate is thin stamped steel. The
> hole often times has slop that will be accentuated by the threads of the
> axle. Ive seen a few bent axles too. Aluminum backing plates are thicker
> around the axle and much better fitting. I do it to all of them
> regardless.
> Try it, you might like it.
Thanks for that^ . :)
I'm always learning .
I'm use to the bigger bikes that usually have a pretty substantial brake plate .
