Re: Garelli brakes wearing out quickly
live ɘvil /
The Garelli (others too) brake backing plate is thin stamped steel. The hole often times has slop that will be accentuated by the threads of the axle. Ive seen a few bent axles too. Aluminum backing plates are thicker around the axle and much better fitting. I do it to all of them regardless.
Try it, you might like it.
