> live ɘvil Wrote:
> Before you tighten axle nuts, wrap a bungee cord around that brake lever
> and handle bar to apply brakes as you tighten the axle. This will center
> the backing plate and pads within the drum to help improve wear and
> braking power.
I've seen that^ posted before .
Doesn't the brake plate have a hole only big enough for the axle , which should center it ?
Or , are we concerned about a severely bent axle ? If so , are they commonly that weak ?
