Re: What's wrong with this exhaust?
P D /
> john cervini Wrote:
> I like to cut my own as well but this one ripped coming off so I have no
> template. I searched the wiki for a template with no luck.
Flip the cylinder up side down. Measure the sleeve and cut that circle out . Oil the flat mating surfaces and slide the cut out over the sleeve . Press the cut out on the flat and remove . The underside will have a perfect outline of what you need . ;)
