Re: tomos sprint stock a35
♣Slew Foot♣ /
Stock Factory idle setting you open your throttle wide open hold it turn the idle screw all the way in then 4 1/2 turns out that will give you the ballpark Idol and you fine-tune it from there if your pipe isn't clogged and you have a NGK b6hs spark plug gap to about .3 you're jetting should be about a 68 or a 70 without a restrictive filter 60 264 with a restrictive filter your timing mark with a normal Tomas base gasket would be just about dead center between the two black marks that's the starting point and you tune up from there
