It should 4 stroke in limited circumstances. Yours sounds like it is doing so too often. First, ride it around for 15-20 minutes and see if the bogging reduces or goes away once it is fully up to temperature. Your stock exhaust may be clogged with carbon as well - especially since you are running such a small jet and still bogging. And you did over-oil the air filter but I guess you tried it without the filter. If your exhaust is clear and it stills bogs too much, try a 67.
Re: Help for a new guy? QT question
