Help for a new guy? QT question
Geoff L /
Recently was gifted a 1980 QT50, non-running for 20+ years. The usual story: Lot's of bad varnished gas. I cleaned the tank and replaced the carb with aftermarket. I put a Niche 60cc piston/head kit on it. Ran like a champ for break-in and about 30 minutes. Unfortunately I believe it is soft seizing. I was hoping not to get into the crank seals but that's where I'm at today. I replaced the left side under the stator easy enough but I wrecked a new seal installing on the right side. There is the bushing/collar on the shaft and one end is beveled. I believe the beveled end faces into the motor. The collar that I'm referring to is #6 on the attached drawing.
I couldn't get the new seal on to the collar when the collar was already on the shaft. Is there a special order of installation? For instance, should I put the seal into the case and then insert the collar into the seal? This could make sense since the beveled edge would be the leading edge. Or would this wind up pushing the seal in too far?
Finally, how do you guys know for certain when your oil pump is working? I have no problems with premixing but I need to research how to delete the pump.
Thanks,
  Help for a new guy? QT questionTopic by: Geoff L Geoff L 09/03/19 10:54PM
  Re: Help for a new guy? QT questionRe: Bob Naske Bob Naske 09/04/19 05:13PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/04/19 11:55PM
  Re: Help for a new guy? QT questionRe: Aaron Blair Aaron Blair 09/05/19 06:50AM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/05/19 02:11PM
  Re: Help for a new guy? QT questionRe: Jack Rutherford Jack Rutherford 09/05/19 05:39PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/05/19 06:30PM
  Re: Help for a new guy? QT questionRe: Captain Janeway Captain Janeway 09/05/19 08:00PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/05/19 11:25PM
  Re: Help for a new guy? QT questionRe: Jack Rutherford Jack Rutherford 09/05/19 11:40PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/06/19 10:54PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/05/19 06:27PM
  Re: Help for a new guy? QT questionRe: Jack Rutherford Jack Rutherford 09/05/19 07:57PM
  Re: Help for a new guy? QT questionRe: Bob Naske Bob Naske 09/06/19 06:45AM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/06/19 10:11PM
  Re: Help for a new guy? QT questionRe: live ɘvil live ɘvil 09/06/19 11:37PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/07/19 01:15AM
  Re: Help for a new guy? QT questionRe: P D P D 09/07/19 08:19AM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/07/19 01:56PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/07/19 02:03PM
  Re: Help for a new guy? QT questionRe: Bob Naske Bob Naske 09/07/19 07:31PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/07/19 11:03PM
  Re: Help for a new guy? QT questionRe: live ɘvil live ɘvil 09/07/19 11:58PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/08/19 12:50AM
  Re: Help for a new guy? QT questionRe: live ɘvil live ɘvil 09/08/19 01:22AM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/08/19 01:29AM
  Re: Help for a new guy? QT questionRe: Jack Rutherford Jack Rutherford 09/08/19 08:46AM
  Re: Help for a new guy? QT questionRe: Bob Naske Bob Naske 09/08/19 09:30AM
  Re: Help for a new guy? QT questionRe: Jack Rutherford Jack Rutherford 09/08/19 10:19AM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/08/19 11:43AM
  Re: Help for a new guy? QT questionRe: Jack Rutherford Jack Rutherford 09/08/19 12:02PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/08/19 06:44PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/11/19 09:44PM
  Re: Help for a new guy? QT questionRe: Jack Rutherford Jack Rutherford 09/11/19 11:17PM
  Re: Help for a new guy? QT questionRe: Jack Rutherford Jack Rutherford 09/11/19 11:18PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/12/19 12:04AM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/12/19 06:29PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/12/19 07:24PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/12/19 07:28PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/12/19 08:55PM
  Re: Help for a new guy? QT questionRe: P D P D 09/12/19 09:06PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/12/19 09:17PM
  Re: Help for a new guy? QT questionRe: P D P D 09/12/19 09:30PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/12/19 09:23PM
  Re: Help for a new guy? QT questionRe: Jack Rutherford Jack Rutherford 09/13/19 10:44AM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/13/19 11:59PM
  Re: Help for a new guy? QT questionRe: Jack Rutherford Jack Rutherford 09/14/19 06:17PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/14/19 07:53PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/12/19 09:46PM
  Re: Help for a new guy? QT questionRe: P D P D 09/13/19 07:35AM
  Re: Help for a new guy? QT questionRe: P D P D 09/13/19 07:55PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/13/19 08:27PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/14/19 04:08PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/18/19 07:50PM
  Re: Help for a new guy? QT questionRe: Jack Rutherford Jack Rutherford 09/20/19 08:46AM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/20/19 10:00AM
  Re: Help for a new guy? QT questionRe: Johnny S Johnny S 09/21/19 09:11PM
  Re: Help for a new guy? QT questionRe: P D P D 09/21/19 09:56PM
  Re: Help for a new guy? QT questionRe: Jack Rutherford Jack Rutherford 09/21/19 10:34PM
  Re: Help for a new guy? QT questionRe: Geoff L Geoff L 09/21/19 11:19PM
