update on previous replies, fitted new stator, new ht lead, new plug, new thyristor, with built in coil ect. and it totally refuses to spark of any kind. re did the timing as the new stator has no timing mark, all seems correct as the manual says, so what am i missing??
I have found a good video on you tube, for all jawa 210 owners. check this out, very interesting, unfortunately in hungarian, could not get a translation, but it is very clear what he is doing, i wired mine exactly the same, before i saw the video, so pleased to see i got it right, but mine will NOT fire. see how easily his starts, he did no even bother with the timing, just screwed the stator on.
Also he had the same thyristor with the built in coil. so why won,t mine fire. wondering if a new wiring harness will find a cure. The video is babbetta gyujtas bekotes. does anyone know if i removed all the coils on the stator, except the exciter coil for the pick up pulse coil, would it still fire, as i don,t need the others for lights ect. or does it need them all to get a spark. tested the thyristor with my new digital multimeter and the wires to the stator, cannot find a fault.
