Re: E50 build, Tunturi City engine swap
Arwid V /
> Aaron Blair Wrote:
> You need an complete engine, bearings, seals, maybe a new crank, a kit,
> tunable clutch, intake, carb, exhaust, skills and a welder. Cdi or
> points ignition, pick your flavor.
> Fabricate mounts with proper chain spacing, weldem on. Paint.
> Then your gonna need to tune the clutch, jet the carb, you'll need a
> custom exhaust mount....starter clutch lever..
> Wiring should adapt pretty easily.
> Or, you could take the money your gonna spend and buy a good Puch moped.
> But good luck!
I'm pretty sure I could buy several running Puchs for the money I'm about to cough up for this project.
And to clear things up..I have some experience myself, but never had an E50. I'm pretty sure it will fit just fine. This moped actually had it stock until 1990'ish when Tunturi for some reason changed the E50/Bing carb to the Morini with Dellorto carb. It might not be a straight fit, but nothing a little welding can't sort.
I also have sandblasting equipment available, so might do the frame, too.
I will order bits and pieces every month, and hopefully have everything ready before next season.
Now I'm waiting for the engine to arrive from the Netherlands. First step is to clean it up, and decide on what crankshaft I want. That will be the next order, along with clutch, all the bearings, seals, clips, bolts, washers etc..
I was thinking of getting a Swiing crankshaft. I'm sure any quality crank would do, especially since I'm not building any kind of top-end monster racer, but the Swiing just seems..nice :) And Swiss-made. Can't be bad!
They have it at Puchshop..
Rito is my second alternative, but I'm reading really mixed reviews about them. I guess my previous argument stands here also, any crank would actually do and getting some expensive fancy racing crank is pretty much overkill.
..but is there any harm in having one? (edited)
  E50 build, Tunturi City engine swapTopic by: Arwid V Arwid V 09/02/19 10:42AM
  Re: E50 build, Tunturi City engine swapRe: Arwid V Arwid V 09/02/19 10:45AM
  Re: E50 build, Tunturi City engine swapRe: Aaron Blair Aaron Blair 09/02/19 11:07AM
  Re: E50 build, Tunturi City engine swapRe: Arwid V Arwid V 09/02/19 01:32PM
  Re: E50 build, Tunturi City engine swapRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 09/02/19 07:27PM
  Re: E50 build, Tunturi City engine swapRe: Nick Haber Nick Haber 09/02/19 07:54PM
  Re: E50 build, Tunturi City engine swapRe: Arwid V Arwid V 09/03/19 02:15AM
  Re: E50 build, Tunturi City engine swapRe: Daniel '' Daniel '' 09/04/19 01:11AM
  Re: E50 build, Tunturi City engine swapRe: Dirty30 Dillon Dirty30 Dillon 09/04/19 02:54PM
  Re: E50 build, Tunturi City engine swapRe: Arwid V Arwid V 09/04/19 03:17PM
  Re: E50 build, Tunturi City engine swapRe: Bas Autowas Bas Autowas 09/03/19 08:00AM
  Re: E50 build, Tunturi City engine swapRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 09/03/19 10:18AM
  Re: E50 build, Tunturi City engine swapRe: Dirty30 Dillon Dirty30 Dillon 09/03/19 11:31AM
  Re: E50 build, Tunturi City engine swapRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 09/05/19 03:07PM
  Re: E50 build, Tunturi City engine swapRe: Daniel '' Daniel '' 09/05/19 04:01PM
  Re: E50 build, Tunturi City engine swapRe: alex . alex . 09/06/19 03:43AM
  Re: E50 build, Tunturi City engine swapRe: Daniel '' Daniel '' 09/06/19 11:40AM
  Re: E50 build, Tunturi City engine swapRe: Jonathan R Jonathan R 09/04/19 06:48AM
  Re: E50 build, Tunturi City engine swapRe: Arwid V Arwid V 09/04/19 01:36PM
  Re: E50 build, Tunturi City engine swapRe: Nick Haber Nick Haber 09/04/19 01:44PM
  Re: E50 build, Tunturi City engine swapRe: Arwid V Arwid V 09/04/19 01:55PM
  Re: E50 build, Tunturi City engine swapRe: Arwid V Arwid V 09/06/19 12:59AM
  Re: E50 build, Tunturi City engine swapRe: Aaron Blair Aaron Blair 09/06/19 04:27AM
  Re: E50 build, Tunturi City engine swapRe: Bas Autowas Bas Autowas 09/06/19 09:28AM
  Re: E50 build, Tunturi City engine swapRe: Arwid V Arwid V 09/06/19 02:39PM
  Re: E50 build, Tunturi City engine swapRe: Arwid V Arwid V 09/06/19 01:47PM
  Re: E50 build, Tunturi City engine swapRe: Arwid V Arwid V 09/06/19 02:54PM
  Re: E50 build, Tunturi City engine swapRe: Arwid V Arwid V 09/13/19 06:39AM
  Re: E50 build, Tunturi City engine swapRe: Benjamin The Wandering Pacer Benjamin The Wandering Pacer 09/16/19 04:51PM
