Re: Any way to brighten Pacer/Morini headlamp?
Benjamin The Wandering Pacer /
> Stephen Keller Wrote:
> Led would prob need a regulator, try the halogen, clean the reflector
> inside if at all possible.
If you don't mind the flicker on low RPMs the LED does work but can also burn out without being setup correctly. I ran for a year with an LED and it was brighter but the one I used wasn't as bright as I would have liked.
