Re: Tomos was running fine, now it will isle but won’t run
♣Slew Foot♣ /
Run it with the gas cap off I bet your vent is clogged another Maybe the fuel flow something's in your tank clogged in your filter pull the plug see what color it is if you're running rich or lean they'll tell you if there's an air leak
