Re: Tomos was running fine, now it will isle but won’t run
Drake Abrahamsson /
Spray carb or brake cleaner on the joints (intake, head to cylinder, cylinder to base, etc.) and if your moped dies or bogs, you’ve got a leak. Make sure everything is torqued correctly and if it’s not that you’ll need a new gasket. Make sure to use the same thickness gasket that’s already there so you don’t mess with the spacing/squish.
