Got a seized e50 that I'm going to rebuild and its going to be my first go at it. What's a good 50cc kit to go with like a 15mm carb and a circuit pipe?
Good 50cc kit for e50
Re: Good 50cc kit for e50
> circuit pipe?
https://www.doscycles.com/products/puch-tccd-38mm-50cc-cylinder-kit
Second that on the tccd running one hitting 43 mph with 15 bing and proma GP exhaust
yup TCCD 50, it likes to rev also
Will definitely look into this one! Thanks guys
Yep TCCD 50cc
You could always do some porting on a stock cylinder.
Athena 50 is the best
thats a hell'of'a 50 kit to start with, not for beginners
It’s not even hard to tune with a simonini, which some have said is the hardest pipe to hit. Very good low end with this setup.
porting! you can modify the stock cylinders and get better performance than the TCCD, spend time not money and learn along the way yeehaw!
Thanks for all the input. Will have to read up on porting too. Pretty sure the stock cylinder/head/piston I have is toast
> Corey S. Wrote:
> Pretty
Post a couple pics . We'll offer opinions .
Will post some pics after I get it apart..got the head off but the piston is stuck in the cylinder..sprayed it with pb blaster letting it sit...hoping I can get it it apart without wailing on it with a mallet
Puch Magnum cylinder is the best stock puch cylinder on the magnum X it’s rated at 4.2 to 4.5 HP with 17mm bing that goes through a long snaky intake that’s barely 14.8 mm
My 3 magnums that have stock unported cylinders go low 40s with modded stock pipe or 35$ chamber on stock header and beat most mild kitted puch bikes on takeoff
get the tccd kit but from Treats (Dos kit doesnt come w/ gaskets)
while youre there get bearings, seals, hardware, and a crank if you need it
if you plan it all out you'll save $$$ on shipping
If you put in a little extra work to get an angled exhaust to work, the A55 stock cylinder is incredible on an e50 with a properly tuned clutch.
> Daniel '' Wrote:
> This kit is the best.
Whoooops I was thinking the crazy reed version
Ya, he's right here!
