Re: Oxalic acid after-work
Drake Abrahamsson /
> Rebel Moby Wrote:
> A numbers guy eh?
> Oxalic acid is an organic compound with the formula C2H2O4. It is a
> colorless crystalline solid that forms a colorless solution in water.
> Maxi tank is 3.2 litres or 0.845 US gallons so given the rate of its
> acidic and chelating properties,if you are mixing oxalic acid
> (Ethanedioic Acid Dihydrate) powder with hot water at 3 tablespoons to a
> gallon of distilled water (or reverse osmosis filtered water) you can
> expect it to derust the tank in 36.5 hours.
I love you
