Re: Oxalic acid after-work
Rebel Moby /
A numbers guy eh?
Oxalic acid is an organic compound with the formula C2H2O4. It is a colorless crystalline solid that forms a colorless solution in water. Maxi tank is 3.2 litres or 0.845 US gallons so given the rate of its acidic and chelating properties,if you are mixing oxalic acid (Ethanedioic Acid Dihydrate) powder with hot water at 3 tablespoons to a gallon of distilled water (or reverse osmosis filtered water) you can expect it to derust the tank in 36.5 hours.
> Drake Abrahamsson Wrote:
> So I have oxalic acid in my maxi tank right now, cleaning it all out as
> suggestion from a previous post (
> https://www.mopedarmy.com/forums/read.php?6,4301134 ). I've had it in
> for 24 hours and I was thinking of keeping it in for 48. Does anyone
> know if that sounds good? The original oxalic acid discussion said "a
> few days" and I'm a big numbers guy and I like having exact times and
> such. lol
> What should I do after I drain the tank of the oxalic acid? Do I fill
> the tank with a water & baking soda solution to neutralize it? Do I
> rinse it with deionized water? Premix?
> Thanks for the help in advance!
