Re: Oxalic acid after-work
P D /
I believe that is simply a build up of the coating I showed in this pic :
I've had that same experience a couple times and like you said , it comes off fairly easily . I left one part soaking for a couple weeks ( testing ) and that build up was thick . I had to use a stiff brush to remove it . Maybe it has something to do with the type or grade of steel ???
And , as much as I'd like to be , I'm just a satisfied user of Oxalic acid . Definitely not an authority on the subject . ;)
