Re: Oxalic acid after-work
Drake Abrahamsson /
> P D Wrote:
> Like everything else , there are no absolutes .
> Your tank may be more or less rusted than mine was .
> I left the acid mix in my Simplex tank for about 24 hours . Dumped the
> mix into a clean tub . Rinsed the tank with clean water . Inspected and
> decided another day of acid mix was in order .
> Oxalic acid leaves a coating after rinse .
> Note the lower part of the brake plate has been wiped clean . The upper
> part still has the coating .
> https://i.postimg.cc/h45Z1LBP/HPIM1559.jpg
> That coating can be left in the tank . It doesn't hurt anything being
> mixed with fuel .
Thanks for being the authority on oxalic acid! I really liked this method. One question: what’s the crystallization? I left my flywheel cover in some just to see what was going on inside the tank and this was the result. Is that a byproduct of the rust-oxalic acid reaction or could it be a result of the minerals/salts in the sink water I used with the oxalic acid? More curious than anything at this point, it seems like it comes off easily
