Re: Oxalic acid after-work
P D /
Like everything else , there are no absolutes .
Your tank may be more or less rusted than mine was .
I left the acid mix in my Simplex tank for about 24 hours . Dumped the mix into a clean tub . Rinsed the tank with clean water . Inspected and decided another day of acid mix was in order .
Oxalic acid leaves a coating after rinse .
Note the lower part of the brake plate has been wiped clean . The upper part still has the coating .
That coating can be left in the tank . It doesn't hurt anything being mixed with fuel . (edited)
