Re: if you just __ you can fix....
Rebel Moby /
If you just spray carb cleaner over your gaskets while its running you can miss diagnose a vacuum leak and spend countless hours of frustration posting on MA trying to figure out WTF is wrong with the cursed bike and lots of money replacing a perfectly good carb and ignition system, new coil, wire and plug, then go after the rings and headgasket...
...and finally give it a proper leak downtest and post a whiney complaint on MA that you have to change a pair of crank seals after doing all of that work...
  if you just __ you can fix....Topic by: K Olena K Olena 08/28/19 12:08PM
  Re: if you just __ you can fix....Re: ♣Slew Foot♣ ♣Slew Foot♣ 08/29/19 01:30AM
  Re: if you just __ you can fix....Re: baird co baird co 08/29/19 10:18AM
  Re: if you just __ you can fix....Re: live ɘvil live ɘvil 09/06/19 10:13PM
  Re: if you just __ you can fix....Re: Josiah Radebaugh Josiah Radebaugh 08/29/19 10:25AM
  Re: if you just __ you can fix....Re: ♣Slew Foot♣ ♣Slew Foot♣ 08/29/19 05:48PM
  Re: if you just __ you can fix....Re: Overpriced Parts Overpriced Parts 08/29/19 06:12PM
  Re: if you just __ you can fix....Re: Drake Abrahamsson Drake Abrahamsson 08/29/19 09:25PM
  Re: if you just __ you can fix....Re: Ryan Graeme Ryan Graeme 08/29/19 11:51PM
  Re: if you just __ you can fix....Re: K Olena K Olena 08/30/19 12:28PM
  Re: if you just __ you can fix....Re: baird co baird co 08/31/19 10:11AM
  Re: if you just __ you can fix....Re: Captain Janeway Captain Janeway 08/31/19 10:15AM
  Re: if you just __ you can fix....Re: ♣Slew Foot♣ ♣Slew Foot♣ 08/31/19 11:19AM
  Re: if you just __ you can fix....Re: Seth B Seth B 09/01/19 03:41PM
  Re: if you just __ you can fix....Re: ♣Slew Foot♣ ♣Slew Foot♣ 09/02/19 04:27AM
  Re: if you just __ you can fix....Re: live ɘvil live ɘvil 08/30/19 12:41PM
  Re: if you just __ you can fix....Re: Captain Janeway Captain Janeway 08/30/19 01:51PM
  Re: if you just __ you can fix....Re: Stephen Keller Stephen Keller 08/30/19 02:13PM
  Re: if you just __ you can fix....Re: K Olena K Olena 08/30/19 03:46PM
  Re: if you just __ you can fix....Re: Rebel Moby Rebel Moby 08/30/19 05:09PM
  Re: if you just __ you can fix....Re: Rebel Moby Rebel Moby 08/31/19 10:29AM
  Re: if you just __ you can fix....Re: K Olena K Olena 09/06/19 09:51PM
  Re: if you just __ you can fix....Re: ♣Slew Foot♣ ♣Slew Foot♣ 09/07/19 01:59PM
  Re: if you just __ you can fix....Re: Brad William Brad William 09/07/19 01:28PM
  Re: if you just __ you can fix....Re: Bad Cadillac™ Bad Cadillac™ 09/09/19 02:38PM
