Who else has broke an MLM intake?
i might have 150 miles on my build... IF THAT
was getting back from a taco tuesday happy hour, maybe a 6 miles ride round trip... and my hobbit started sounding like it was hurting for fuel. i looked at my line, she was full, then it died,, like when you soft seize kinda noise
i look down and my intake is broken -______________- wtffff
malossi h20 kit, 4pedal reeds + block spacer, this MLM intake, vm20
like,, wut ???
Re: Who else has broke an MLM intake?
♣Slew Foot♣ /
V vibration does funny things obviously there is a lot of weight on it and the weld had a weakness somewhere and it worked its way right off I had the same problems with pipes I had a really good at MLM pipe and the flange broke clean off it was due to high vibration I would suggest that in your next incarnation you put some rubber bushings on the motor so it doesn't vibrate so violently I would also check the balance of your clutch Bell and such
No but ive had a mlm intake break me...haha joking.
Weld that shit up and keep going.
Chris Szuba /
sounds clutch!
ha more puns
Probably Fred /
I’d check your cylinder/top end because it may have sucked some metal in there
Chris Szuba /
> there
good call
Another thought,
Get a snug fitting hose and two hose clamps to mend it back together. The hose will flex enough to prevent it from breaking again.
human error, theres alotta joints there.
same thing happened to me with the vm20 nu50 intake!
Captain Janeway /
so much for quality control. After 150 miles? Jeez.
> live ɘvil Wrote:
> Another thought,
Beach Club Nick /
> alex . Wrote:
> > live ɘvil Wrote:
> > Another thought,
Yeah the intake setup on my Hobbit has been a random piece of radiator hose going from the Malossi 21mm PHBG intake to my carb for 3 years and it hasn't failed me yet.
That looks like a bad weld, no penetration. contact who you got it from about this and send them the pictures. good luck
