Re: Wheels locked up
Andrew Leone /
> Aaron Blair Wrote:
> Those from a compact? Neat!
> Hit those bearings with a torch. Ur gonna replace em' anyway. Squirt
> some kroil in there too.good stuff
So you're thinking torch right down the axle hole? I guess I'm confused as to what is holding it up from spinning. Is it typically the brake assembly rusted to the inside of the wheel or is it something to do with the bearings? I was able to get a look at the bearings on the sprocket side and it doesn't look seized up, still packed with grease.
I'm going to try rigging it up again and hitting it with a torch as you and Lar suggested.
