09...less than 1k in miles. Change a bulb in anything, throttle and it burns out instantly. Ideas....videos to how to repair? Any help is greatly appreciated as I am only a little handy and know 0 about electronics. Thank you in advance for your advice.
All lights blowing out on 09 Tomos Targa LX
Re: All lights blowing out on 09 Tomos Targa LX
Any help is greatly appreciated.
Voltage regulator
Yep your voltage regulator is probably wired wrong or it blue more than likely the one terminal melted possibly due to a ground fault sometimes it's actually something shaking loose considering it's a newer bike I would think something shook loose so double-check all your grounds on the lights also the voltage regulator do you have a battery is it electric start?
These will figure into it, if you go and look check the wiring that goes through the fender and into the frame that is a short spot the wiring can go all wonky in there if the set voltage regulator has a melted terminal or blue out chances are there's a short somewhere
