> Jack Nielsen Wrote:
> Nick: Yes, I am installing a PA50II reed with a PA50II reed block on a
> PA50I motor with a PA50I carb. Are any adjustments to carb required like
> a larger main jet?
> Jack
Nah you'll be fine. If anything you might have to downjet but you should probably not notice anything. The pa50ii reeds are actually much better than the pa50ii so you might notice a slight performance increase.
