> K Olena Wrote:
> sounds like an air leak.
> If you have carb clean let the bike run and spray carb cleaner on your
> gaskets and seals.
> If the motor cuts out...wala you found the leak
It’s not an air leak, I assure you. In 4 years I’ve never built a bike that developed an air leak at surface mating. It’s a fairly new build as well so it’s doubly impossible. I still need to reword that killswitch to find out if that was the issue.
