Re: Puch Maxi: engine cuts out at mid RPMs
Tone It Down /
I’ve considered both these things. The issue just suddenly started out of the blue while out on a ride after about a half season of solid rippage. so I’d be interested to know how due flow issues might change so suddenly. I actually just checked to see if the fuel filter was draining too quickly and with just a quick rip of the throttle, the cutting out happens. Not even giving fuel time to deplete significantly.
But when you’re out of options, it never hurts to try different things. I’ll try the gas cap truck then after that I’ll completely disassemble and reassemble the carb in case there’s a blockage.
Also, note in the video that the headlights don’t flicker when the cutting out begins. Would they cut out if it were an electrical issue or would the fact that lights are a different circuit make it not matter?
And fuel flow issues wouldn’t explain the odd behavior of my fire mark when using a timing light, would it?
  Puch Maxi: engine cuts out at mid RPMsTopic by: Tone It Down Tone It Down 08/21/19 10:29AM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: live ɘvil live ɘvil 08/21/19 10:41AM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: Tone It Down Tone It Down 08/21/19 10:53AM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: live ɘvil live ɘvil 08/21/19 01:05PM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: Tone It Down Tone It Down 08/21/19 01:16PM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: live ɘvil live ɘvil 08/21/19 01:22PM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: Tone It Down Tone It Down 08/21/19 01:33PM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: P D P D 08/21/19 03:05PM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: Tone It Down Tone It Down 08/21/19 06:27PM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: Tone It Down Tone It Down 08/21/19 12:50PM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: Jimmy Crank Jimmy Crank 08/26/19 09:59AM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: Lee Snover Lee Snover 08/26/19 09:20PM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: Tone It Down Tone It Down 08/26/19 10:31PM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: K Olena K Olena 08/28/19 03:56PM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: Tone It Down Tone It Down 08/28/19 04:40PM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: Lee Snover Lee Snover 08/28/19 05:20PM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: Tone It Down Tone It Down 08/28/19 05:22PM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: Tone It Down Tone It Down 09/23/19 05:29PM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: Mike Boyd Mike Boyd 09/23/19 06:04PM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: Potr zebie Potr zebie 09/23/19 08:51PM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: Tone It Down Tone It Down 09/23/19 09:19PM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: todd amundson todd amundson 09/24/19 11:20AM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: Tone It Down Tone It Down 09/24/19 11:50AM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/24/19 05:26PM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/24/19 05:32PM
  Re: Puch Maxi: engine cuts out at mid RPMsRe: Tone It Down Tone It Down 09/24/19 06:20PM
