Re: Fork/Steering slop?
live ɘvil /
> Lee Snover Wrote:
> > live ɘvil Wrote:
> > > Lee Snover Wrote:
> > > > Mike Boyd Wrote:
> > > > Yup that's an additional bearing race, not a washer and not
> original
> > > in
> > > > that order of assembly. There's a race on the bottom of the tube
> too
> > > > right?
> > > Yes, new top and bottom races, top and bottom of frame tube with
> new,
> > > nicely greased bearings. I thought it looked odd, but that is what
> > was
> > > there when I took it apart. The diagrams call for a flat washer.
> My
> > > 1980 has no washer and no slop.
> > Put that original nut on and torque to spec. Recheck steering and
> adjust
> > bearings if neccesary.
> You keep saying "adjust bearings". What do you mean? They get
> installed and the adjustable ring gets adjusted. Not too tight to
> distort the bearings, and not to loose to cause slop. Is there some
> other "adjustment" I'm missing.
> Torquing the head nut is not solving the problem. I tried it with and
> without. The yoke has been distorted I believe. I will fix the yoke or
> get a new one.
95% of the time when you properly torque the top nut the second nut below which is above the top bearings will need adjustment because of thread slop. So you loosen top nut adjust second and re torque top nut and check again.
You do have two nuts on steering stem correct? One maybe knurled instead of hex but its threaded none the less. (edited)
  Fork/Steering slop?Topic by: Lee Snover Lee Snover 08/21/19 12:07AM
  Re: Fork/Steering slop?Re: live ɘvil live ɘvil 08/21/19 12:41AM
  Re: Fork/Steering slop?Re: Lee Snover Lee Snover 08/21/19 12:50AM
  Re: Fork/Steering slop?Re: live ɘvil live ɘvil 08/21/19 01:32AM
  Re: Fork/Steering slop?Re: Lee Snover Lee Snover 08/21/19 02:04AM
  Re: Fork/Steering slop?Re: live ɘvil live ɘvil 08/21/19 02:24AM
  Re: Fork/Steering slop?Re: live ɘvil live ɘvil 08/21/19 02:26AM
  Re: Fork/Steering slop?Re: Stephen Keller Stephen Keller 08/21/19 02:57AM
  Re: Fork/Steering slop?Re: Lee Snover Lee Snover 08/21/19 06:47AM
  Re: Fork/Steering slop?Re: Lee Snover Lee Snover 08/21/19 07:48AM
  Re: Fork/Steering slop?Re: Tone It Down Tone It Down 08/21/19 10:38AM
  Re: Fork/Steering slop?Re: Lee Snover Lee Snover 08/21/19 12:30PM
  Re: Fork/Steering slop?Re: Tone It Down Tone It Down 08/21/19 06:32PM
  Re: Fork/Steering slop?Re: Mike Boyd Mike Boyd 08/21/19 06:36PM
  Re: Fork/Steering slop?Re: Lee Snover Lee Snover 08/21/19 08:13PM
  Re: Fork/Steering slop?Re: live ɘvil live ɘvil 08/21/19 12:29PM
  Re: Fork/Steering slop?Re: Tone It Down Tone It Down 08/21/19 10:32AM
  Re: Fork/Steering slop?Re: Daniel '' Daniel '' 08/21/19 01:45AM
  Re: Fork/Steering slop?Re: Mike Boyd Mike Boyd 08/21/19 04:26PM
  Re: Fork/Steering slop?Re: live ɘvil live ɘvil 08/21/19 04:35PM
  Re: Fork/Steering slop?Re: Lee Snover Lee Snover 08/21/19 05:07PM
  Re: Fork/Steering slop?Re: Mike Boyd Mike Boyd 08/21/19 06:00PM
  Re: Fork/Steering slop?Re: live ɘvil live ɘvil 08/21/19 06:25PM
  Re: Fork/Steering slop?Re: Lee Snover Lee Snover 08/21/19 08:15PM
  Re: Fork/Steering slop?Re: live ɘvil live ɘvil 08/21/19 09:05PM
  Re: Fork/Steering slop?Re: Lee Snover Lee Snover 08/21/19 09:14PM
  Re: Fork/Steering slop?Re: live ɘvil live ɘvil 08/21/19 09:21PM
  Re: Fork/Steering slop?Re: live ɘvil live ɘvil 08/21/19 09:32PM
  Re: Fork/Steering slop?Re: Lee Snover Lee Snover 08/21/19 09:40PM
  Re: Fork/Steering slop?Re: live ɘvil live ɘvil 08/21/19 09:47PM
  Re: Fork/Steering slop?Re: Lee Snover Lee Snover 08/21/19 05:09PM
  Re: Fork/Steering slop?Re: Norris Hall Norris Hall 08/22/19 04:46PM
  Re: Fork/Steering slop?Re: Lee Snover Lee Snover 08/22/19 06:29PM
  Re: Fork/Steering slop?Re: live ɘvil live ɘvil 08/22/19 06:39PM
