Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?
Bob Blarney /
Aaron, no, there is no CDI.
The alternator provides current for three functions, with three separate coil windings (see shopmanual image):
1. Ignition (blk/wh wire) leading to the ignition condenser & coil under the seat.
2. Lights (yellow wire) leading to the light switch on the left handlebar.
3. Battery charging (white wire) via the rectifier diode under the seat.
There is no continuity to ground through the yellow and white wires within the alternator, and the ohmmeter reads infinite resistance for both wires.
There is continuity to ground through the ignition circuit within the alternator, but it could be that the points are closed but the coil winding is open too.
I think it's time to remove and examine it, and probably replace it.
  spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Topic by: Bob Blarney Bob Blarney 08/20/19 10:21AM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: live ɘvil live ɘvil 08/20/19 11:56AM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/20/19 01:25PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: live ɘvil live ɘvil 08/20/19 01:39PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/20/19 02:44PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Nick MBC Nick MBC 08/20/19 03:30PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/20/19 04:53PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: live ɘvil live ɘvil 08/20/19 05:10PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: live ɘvil live ɘvil 08/20/19 04:19PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Jack Rutherford Jack Rutherford 08/20/19 05:08PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/20/19 06:13PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Aaron Blair Aaron Blair 08/21/19 04:52AM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/21/19 07:41AM
