Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?
Aaron Blair /
Did you clean the points? Are the points opening? Are those two wires without continuity going to the points?if so it's normal. Because the points are open at that time. Spinner until you have continuity.
Measure the resistance on both sides of the ht coil(it's a transformer). The whole "alternator" as you called it can't be toast, worse case scenario your ignition coil is shorted. In which case you pull the flywheel and replace it.
Wait, does the express have a cdi? If so,lol disregard. (edited)
  spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Topic by: Bob Blarney Bob Blarney 08/20/19 10:21AM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: live ɘvil live ɘvil 08/20/19 11:56AM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/20/19 01:25PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: live ɘvil live ɘvil 08/20/19 01:39PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/20/19 02:44PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Nick MBC Nick MBC 08/20/19 03:30PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/20/19 04:53PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: live ɘvil live ɘvil 08/20/19 05:10PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: live ɘvil live ɘvil 08/20/19 04:19PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Jack Rutherford Jack Rutherford 08/20/19 05:08PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/20/19 06:13PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Aaron Blair Aaron Blair 08/21/19 04:52AM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/21/19 07:41AM
