Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?
live ɘvil /
> Bob Blarney Wrote:
> > Nick Haber Wrote:
> > > Bob Blarney Wrote:
> > > Your comments have no relevance to the problem. The starter system
> > > works perfectly.
> > > The problem is in the electrical generation system. The important
> > point
> > > is that the shop manual warns that rotating the crankshaft in the
> > > 'wrong' direction may somehow damage the generator - the ignition
> and
> > > the lighting and battery charging circuit components.
> > > I'm wondering if, during the installation of starter crankcase, that
> > the
> > > generator flywheel was rotated in the clockwise direction, and so
> > > damaged the electrical system.
> > Are you trying to troll? Read what has been said again; the shop
> manual
> > warns that not to protect the electrical system but to protect the
> > starter mechanism. Wind that shit backward then go to start it and
> > you'll see what he means cause your starter spring will break.
> > He's saying your electrical issue has nothing to do with the flywheel
> > being rotated the wrong direction. From an electronics standpoint,
> that
> > doesn't really make sense. Nothing has been damaged from magnets
> > spinning the opposite rotation of normal operation
> I think you misunderstand something.
> I don't know if the previous owner spun the engine backwards when the
> e starter case and mechanism was removed from the engine.
> The engine was not spun backwards while the starter mechanism was
> installed and in place. It is not damaged in any way. The flywheel was
> only jiggled when I re-engaged the pawls on the starter sprocket.
> For that matter, I'm inclined to think that spinning the crankshaft by
> hand (when the starter case & mechanism is removed) should not have any
> effect on the electrical system or the mechanical systems. But it is
> stated specifically as a warning in the shop manual, on page 12-1 (see
> attached image) "Never turn flywheel clockwise during disassembly or
> reassembly."
Let me know when you get to this point in your rebuild.
  spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Topic by: Bob Blarney Bob Blarney 08/20/19 10:21AM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: live ɘvil live ɘvil 08/20/19 11:56AM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/20/19 01:25PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: live ɘvil live ɘvil 08/20/19 01:39PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/20/19 02:44PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Nick MBC Nick MBC 08/20/19 03:30PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/20/19 04:53PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: live ɘvil live ɘvil 08/20/19 05:10PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: live ɘvil live ɘvil 08/20/19 04:19PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Jack Rutherford Jack Rutherford 08/20/19 05:08PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/20/19 06:13PM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Aaron Blair Aaron Blair 08/21/19 04:52AM
  Re: spinning the NC50 alternator clockwise kills it, and the rectifier & coil?Re: Bob Blarney Bob Blarney 08/21/19 07:41AM
